After creating a prototype, all components can be soldered to the board:
You can combine two or more boards:
To the boards you can solder terminal blocks:
The boards are designed for installation to DIN-rail enclosure:
DIN-rail enclosure with a board in assembly:
Example project with different sensors:
This project in DIN-rail enclosure:
Two tires can be connected with a jumper:
Comparison of classic breadbord and protoboard-uni:
For different size of enclosure boxes a line of protoboards-uni has been developed.
More details?
