ServoDroid: Control servos and LEDs with Android
Requiring no setup and no programming experience, ServoDroid makes it easier than ever for makers and developers to build robots
Your mobile phone already knows where it is, how you're holding it, and what’s around it. What if you could use it to control your own inventions? ServoDroid is a tiny board that allows you to control motors and LEDs directly from your phone. With ServoDroid you can build Robots, camera mounts, Light activated lamps, and basically anything that contains a servo or LEDs.
ServoDroid is a handy tool for all makers. It requires no setup, just plug it into your phone's audio jack and you can start controlling robots. Featuring a drag and drop programming language it helps promote STEM education, while making it easier for makers to prototype their ideas.
Early bird ServoDroid boards are available on IndieGogo: https://www.indiegogo.com/projects/servodroid-control-anything-with-your-phone
Your mobile phone already knows where it is, how you're holding it, and what’s around it. What if you could use it to control your own inventions? ServoDroid is a tiny board that allows you to control motors and LEDs directly from your phone. With ServoDroid you can build Robots, camera mounts, Light activated lamps, and basically anything that contains a servo or LEDs. ServoDroid is a project which I'm currently funding on IndieGogo.
  • 1 × 1 ServoDroid Board
  • 1 × 4 AA batteries
  • 1 × battery holder
  • 1 × jack to jack 3.5mm cable
  • 1 × Servo Motor
  • 1
    Step 1
    Plug the board into your Android phone via the audio jack.
  • 2
    Step 2
    Power it up with 4 AA batteries or any 6v DC source.
  • 3
    Step 3
    Connect a servo motor to the board.
View all 5 instructions
