The Scanner Box
A project log for Little Monster Scanner
In preparation for Halloween this year I want to make a scanner to find those "little monsters" for some animatronics fun.
agpcooperagp.cooper 01/09/2018 at 01:270 Comments
A Narrow Scan PIR
The PIR datasheet (and bandpass of the electronics) indicate that the sensor will respond to signals up to about 10 Hz but at reduced sensitivity. Therefore scanning for "Little Monsters" (LMs) is feasible.
The next step is to consider a suitable narrow beam "lens". After much research the lens became a vertical slot. The slot is designed for an apperture of 10 to 15 degrees horizontally and 30 to 40 degrees vertically:
Here is the SE-10 mounted inside the box:
The initial testing worked great:
Without a suitable motor base, the sensor moves too much when scanning but it was clear that "fast" scanning works.
AlanX
