Zilog Z8000 technical manual in html form.zipTechnical manual, partial conversion to html.Zip Archive - 34.81 MB - 11/12/2021 at 20:30 |
Zilog Z8000 programmers guide.zipApplication note about Z8000 programming, in html form.application/zip - 76.90 kB - 11/12/2021 at 19:13 |
STE-Z8001_glue_logic_1.eqn.txtFirst draft logic equations to fit the 4sun5bu design TTL circuitry into a single 22V10 chip. Not compiled or tested yet!plain - 2.82 kB - 11/11/2021 at 13:32 |
Z8000_BASIC-lst.txtThe listing allows the data words to be checked against the assembler statements. It has allowed me to spot and correct several mistakes in both parts.plain - 116.40 kB - 11/09/2021 at 16:05 |
Z8000_BASIC-src.txtAvoids the need for a Z8000 assembler by taking the listing from the book, turning the Z8000 assembly statements into comments and the hex data into code that most assemblers can handle. Unchecked and untested.plain - 46.56 kB - 11/09/2021 at 16:05 |
Byte Z8000 Trump Card articles in html form.zipPartial conversion to html, should be a lot nicer to read. Circuitry all horizontal, colour pictures, etc.Zip Archive - 11.72 MB - 11/07/2021 at 03:58 |
Basic Interpreter-8085-listing.txtZ80 CP/M Tiny BASIC listing. Assembled but untested.plain - 104.19 kB - 05/15/2021 at 01:59 |
Basic Interpreter-8085-source.txtZ80 CP/M Tiny BASIC Source code. Assembles but untested.This is the basis from which the Z8000 version was ported. See book by Rolf-Dieter Klein. plain - 17.12 kB - 05/15/2021 at 01:59 |
Basic Interpreter-8085-intel-hex.txtZ80 CP/M Tiny BASIC Source code. Assembled but untested.plain - 7.27 kB - 05/15/2021 at 01:59 |
Basic Interpreter-Z8000-source.txtRough OCR edited. Probably has many errors, has not been put through an assembler yet.plain - 23.44 kB - 05/09/2021 at 00:03 |
