Hackaday.io Hackaday.io
Sign up Log in
2D Laser Range Finder under $80
A 2D Laser Range Finder with 100 degree field of view for under $80 with no moving parts
rlsutton1rlsutton1
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
29 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
649
0
29
2
Team (1)
  • rlsutton1rlsutton1
Join this project's team
completed project
This project was created on 09/07/2014 and last updated 11 years ago.
Description
I've seen other Laser Range Finders using a dot laser and a web cam, and decided I could use a line laser and multiple web cams to produce a field of laser ranges. 2 Logitech c270 web cams provide a 100 degree field of view, and a common 5mw line laser with a 120 degree lens provides a line across the entire field of view. I've designed a mount to off set each web cam 25 degrees respectively left and right, also tilting them up 11 degrees to make their vertical field of view from horizontal to ~+22 degrees. The laser is mounted 110mm above the base and this gives the range finder a theoretical range from ~20cm to infinity. I've written a custom image processing algorithm in java leveraging opencv via javacv see the video in the project logs
Project Logs
Collapse
  • Video of a basic test
    rlsutton1 • 09/09/2014 at 20:34 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Draw patterns on the surface of a table using glow-in-the-dark paint and a laser pointer.
Project Owner Contributor
Laser Table
ben-wienerBen Wiener
3D printed holder for two line and one point laser allowing targeting and focusing of laser cutter head.
Targeting Laser for Laser Cutter
florian-festiFlorian Festi
WYSIWYC- What you see is what you (laser)cut
Augmented Reality Laser-cutting/CNCing
touchaddicttouchaddict
Using a DVD burner laser as a projection microscope
Laser Projection Microscope
jJ
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "2D Laser Range Finder under $80", please tell us the reason.
Send message
Remove Member
