S/PDIF Digital (Optical TOSLINK) Output
A project log for Teensy Audio Library
CD quality sound processing, integrated with Arduino sketches
paul-stoffregenPaul Stoffregen 06/07/2015 at 01:293 Comments
Thanks mostly to Frank B, we now have direct S/PDIF output from the Teensy Audio Library!
Here's a detailed blog article.
You can get optical TOSLINK digital audio with a $1 connector (Digikey 1080-1434-ND) or just a red LED shining into the optical cable.
In the photo above, the TOSLINK connector is mounted on this OSH Park PCB (under $2 for three of them).
The S/PDIF output is also now supported by the Audio System Design Tool, so you can just connect it to whatever complex audio system you like, to get S/PDIF digital output!
Here's the lengthy forum thread where this development was discussed.
Michele Perla wrote 06/09/2015 at 10:16 point
Epic stuff! @Paul Stoffregen , you really are changing the world of diy audio with the Teensy Audio Library!
Paul Stoffregen wrote 06/08/2015 at 23:52 point
I wonder if anyone will say it's not a hack?!
Mike Szczys wrote 06/08/2015 at 23:46 point
This is utterly incredible! Great work, and a wonderful read
