Who needs pad addresses? Pt2
A project log for Hackaday Cipher Utility
Web based tool to automate ciphering/deciphering using hackaday one time pad
gannongannon 10/07/2014 at 21:100 Comments
I've gone through and restructured the code to be more efficient and cleaner. This was mainly to support bruteforcing the ciphers.
The brute forcing page is currently separate from the main page and can be found at http://otp.portablesofdoom.org/brute.html
I have only tested it with a few messages, but it works. It takes a little bit of time to respond though, so be warned.
