POWER SUPPLY
A project log for VGA VIDEO SYNTH
vga analog video synth
julienJulien 09/27/2018 at 11:290 Comments
An important piece of the project is done, the power supply. I couldn't put it in the box so I made a external one. The power is +12/0/-12V so I needed a 3 connectors plugs. I ordered these microphone plug for that task. The output is given at 500mA for each rail. I put two output in order to connector other circuit if need be.
You need to go soft on those plastic faceplates. lesson learned for the next one.
