Crane assembly design change
A project log for Strong Arm
A robotic arm with at least human size and strength with 6 degrees of freedom
garrett-herschlebGarrett Herschleb 09/28/2014 at 00:050 Comments
I've found that the current design for the crane axes were a little rickety (even with all that metal) and presented manufacturing difficulties.
So now instead I've adopted an MDF-aluminum composite that will be much easier to make and more solid without increasing BOM cost.
See the 3D rendering of the new design.
