Updated Design with Grips
A project log for Strong Arm
A robotic arm with at least human size and strength with 6 degrees of freedom
garrett-herschlebGarrett Herschleb 08/29/2015 at 13:550 Comments
The grips are based on 3/4" aluminum square tubes. The predicted squeeze strength is around 40 pounds.
What about safety? Using PyUltimateRobot (see that Hackaday page), one can limit maximum force of any component of any movement. For example, you can program the robot to never use more than 1 pound of force unless explicitly commanded as needed for a particular movement.
