Arduino room automation
A system, which allows me to read data like
temperature on my smartphone,
and control stuff like lights, heating and so on
The whole system will be based on a Arduino Mega. To comunicate with a smartphone I will use an bluetooth module and maybe a Raspberry Pi to connect it via W-Lan. Also It will contain an LCD-Display to display data directly.
  • Light switch working
    avus1709/30/2014 at 16:21 0 comments
    Just a small update, I attached the whole light switch mechanism, and it works the way I want it to :-) ,
     next I will add the bluetooth module so I can control it using a smartphone. Later the electronics will
    be placed inside my wardrobe which is next to the  door, but first I need a new place to store my socks ;-) .
  • Light switch
    avus1709/28/2014 at 18:28 0 comments
    First thing I want do do is to control the light switch. Because I don't want to mess around with
    230 volts, I will use an servo to operate the light switch mechanically. I
    put the whole thing into an
    aluminium box so it doesn't look that messy ;-). Also I added two buttons, one to turn on the lights, and one
    because I want to add an motion sensor later so I can activate it using the second button.
View all 2 project logs
Moritz Walter wrote 10/01/2014 at 20:16 point
Nice home automation project and very well done, I like the servo light switch idea! If you plan to add temperature control, you might want to check out the servo controlled heater valve from my BASH project: http://iamnotachoice.com/bash/
Jasmine Brackett wrote 09/25/2014 at 00:34 point
Hey avus17, looking forward to seeing more about your project. You might be interested in our Home Automation list http://hackaday.io/list/2401-Home-Automation.
