Metal oxide first attempt
A project log for Better Homemade Resistors
Homemade resistors that are better than the pencil lead carbon and low-ohmic wirewound resistors people normally make.
spockopolisSpockopolis 09/29/2014 at 23:050 Comments
 I figured the easiest way to make a metal oxide resistor would be to fill a tube with iron oxide and put wire in the end. I did just this. A got a short length of 3mm OD glass tubing, placed a peice of 14AWG copper wire in one end, poured powdered iron oxide (made from steel wool) into it, and placed another wire in the other end. When I connected my meter I discovered an annoying fact. Iron Oxide (FeO2) is completely non-conductive. I think after that fail carbon composite is my best shot.
