Adding a power switch?
08/17/2015 at 17:54 • 0 commentsWe are pondering adding a power switch. Right now the USB connector powers everything directly. If we add a switch, it will need to be a DPDT for both 5V and 3.3V.
10W limit
08/17/2015 at 17:52 • 0 commentsUntil we can produce a USB PD or Quick Charge based power supply, our ability to drive lighting is limited to 10W per system.
Mic addon
08/16/2015 at 08:53 • 0 commentsIn addition to phone based control, the design now accommodates a MEMs Mic Flex Module. This should allow the lighting to respond to any ambient music. We will have to see how well we can real time process the i2s stream, but it might be a good feature.
New layout design
08/16/2015 at 08:50 • 0 commentsWe have reworked the design some so that the Dance kit can fold into a square or wrap as strap. This should allow it to fit into a pocket, fit in behind a lighting panel, wrap around a power bank, or become a bracelet.
