close-circle
High voltage clearance
A project log for MAX14521E EL Driver Flex Module
This is a Flex Module that drives 4 EL 'lamps' by i2c control. It supports audio modulation. For sale on Tindie.
Chris HamiltonChris Hamilton 04/04/2015 at 18:150 Comments
I am redoing the layout as the spacing to follow IPC-2221B better near components. Otherwise, I'll be working on software for this board and finishing testing with the current design.
