• 1
    Start with a piece of perf board 8 holes wide by 11 holes tall. We used used Plated through holes for prototyping, but this layout will work with PTH or single layer boards. Be careful cutting and/or sanding the board - fiberglass dust is nasty stuff. To minimize dust, We suggest using a pair of tin snips to cut the board, or the tried and true "score with a knew and snap" method.
  • 2
    Solder in an 8 pin socket for your ATtiny85. Leave two holes free below the socket and two on each side.
  • 3
     Solder in the 0.1uf bypass cap just above the upper right pin of the ATtiny.
    Bend the leg of the capacitor down and solder it to pin 8 (VCC) of the ATtiny. The other capacitor leg can be soldered in straight.
