Prototype Mk1 PCB
A project log for Neuron Tech
Home Automation and Security
michael-otooleMichael O'Toole 10/27/2014 at 02:010 Comments
Although still using full size Micro, I thought I build up a prototype board...
And schematic....
The final PCB size could be as small as 13mm high, 15-20mm wide by 30-40mm long, assuming a 3 volt cell or small rechargeable....
Will add header to allow plugging in of the 1.8" TFT Debug Module,,,
