Connect the Adafruit Ethernet FeatherWing to Ubidots
A project log for Adafruit Ethernet FeatherWing to Ubidots
Learn how to setup your Adafruit Ethernet FeatherWing with Ubidots
maria-carlina-hernandezMaria Carlina Hernandez 01/11/2018 at 16:080 Comments
The Adafruit Ethernet FeatherWing is the perfect option for permanent installations with wired and reliable internet connections. What we like most about the Ethernet FeatherWing is that it works with the entire Feather board series and can be simply managed to run a number of different applications with high data rates.
Visit the Adafruit site to learn more about the Ethernet FeatherWing.
In the following tutorial, Ubidots will demonstrate how to setup and program the Adafruit Ethernet FeatherWing using the Arduino IDE to visualize and interpret data using Ubidots.
