To make a pumpkin that lights up when it hears noise
Make your circuit of Battery-->Power-->Sound Trigger-->Bright LED
Place your circuit inside your carved pumpkin. By adding the Sound Trigger, the Bright LED will turn on when it hears noise. Use the included Shoes to help adhere your circuit to the pumpkin as needed.
To make a pumpkin that lights up and stays on
Make your circuit of Battery-->Power-->Bright LED
Place your circuit inside your carved pumpkin (similar to the above, you can use the included Shoes to help adhere your circuit to the pumpkin as needed)
littleBits
Silícios Lab
bornach
