littleBits Stick Figure Costume
Glow your way to greatness with this classic costume
Glow your way to greatness with this classic costume. Simply sew light wire into your clothing in the shape of a stick figure! Add the pulse for complete party status.
The light wire has been a crowd fave for our bitizens, using it to invent customized light-up costumes for years. Now we have a super easy way for everyone to make their own costume guaranteed to light up any costume party or trick-or-treating!
To make a stick figure that lights up and stays on
Make your circuit of Battery-->Power-->Light Wires
You can sew the light wires onto a dark piece of clothing or use the hook & loop Shoes to easily attach to clothing
To make a light-up costume that blinks:
Make your circuit of Battery-->Power-->Pulse-->Light Wires
By adding the Pulse the lights will blink. Similar to the above, you can sew the modules to dark clothing or attach with the Shoes
  • 1 × littleBits battery + cable
  • 1 × littleBits Power Module
  • 1 × littleBits Pulse Bit
  • 2 × littleBits Light Wire
  • 1 × littleBits Shoes
  • 1
    Step 1
    Build this circuit: power + pulse + light wire + light wire. Adjust the pulse to whatever speed you like.
  • 2
    Step 2
    Use the hook & loop bitsnaps to secure your circuit so they dont separate. Use the adhesive hook & loop strip to adhere it to your material.
  • 3
    Step 3
    Bend the lightwire into the shape of a stick figure. The lightwire is great because it holds the general shape once you bend it.
View all 5 instructions
