PCB soldered and first RGB test
A project log for RGB LED-strip driver over WiFi
RGB LED-strip driver using PIC16LF767 and ESP8266. Control via Android app.
bertvanoBertVano 01/20/2016 at 19:550 Comments
Hello
It's been a while since I've updated this page but here it is:
The soldered PCB with first RGB tests via PWM.
Close-up from the PCB on/off
Now I'm going to set up the ESP8266 connection with the PIC.
First I'll write a basic init method and after that I'll do some tests on character sending/receiving
