I finally got around to designing the belt clamps that will attach to the bottom of my X axis gantry plates. This is a simple design and will only require 2 screws to keep the belts tight and in place.
I will be machining these out of HDPE.
A project log for Simple DIY laser cutter
Basic laser cutter than can be made with standard shop tools.
