I have decided to flip the X axis stepper on top on the X axis. The reasons for this are I cut out needing 2 idler pulleys and the motor mount can be simplified meaning both motor mounts are the same!
Although I lose a little X axis cutting space it's not enough to worry about and should speed up the build process. More pictures to follow soon!
