Handle and company...
A project log for Simple DIY laser cutter
Basic laser cutter than can be made with standard shop tools.
philphil 03/21/2014 at 20:470 Comments
I've not had much time this week for the machine and I'm still waiting for the belts and openrail to arrive so I have made the front idlers, both stepper motor brackets and the handle.
This is made so it goes bearing, washer, GT2 pulley and nut.
The handle is a pretty simple design:
and the stepper bracket I laser cut from 3mm black acrylic.  I used the laser but it can be made with a drill press easily but I need an eye test!  Pictures to follow because the camera battery just died.
