First Parts Came In!
A project log for Gator Quad
Personal project to develop a quad copter using as much self designed circuitry and software as possible.
ridonkulusridonkulus 10/20/2014 at 18:140 Comments
Summary:
My first order of parts came in today. I am starting with the basics for right now. My goal is to get a BLDC motor driver up and running for 1 motor with the same MCU that will be used on the GatorQuad, and then go from there. This will allow me to start to prove the concept while saving as much of my code and work moving forward.
Parts Ordered:
The motor was ordered from Hobby King because it was inexpensive and widely used. I did not know what I was getting with it because It's Hong Kong manufacturer "Turnigy" does not have a lot of documentation online. This motor does not come with built in Hall effect Sensors for sensored control. I ordered a few bullet style connectors from HobbyKing so i can make and connect my own wire. Thus I ordered some from Sparkfun and hope they will fit my needs. I did not notice when I ordered the Hall effect sensors that they are a latching version, so I will find out if that will effect my control and ultimately may need to order non latching sensors. The TI Power mosfets are capable of sourcing 50A of drain current while the motor is only rated for 20A. Obviously I way over sized here, these will likely be scaled down in later designs, but for now I wanted to be on the safe side. Picking the gate drivers was a little tricky, the main things that I wanted was independent control of the High side and Low side of an H-bridge, as well as enough source current to switch the mosfets fast enough. I found scattered resources across the web to help with determining the source current for certain mosfet capacitance's and switching speeds. Right now I think I am okay, If my calculations were wrong we will revisit this. The gate drivers were a small SOIC package and I am doing my initial prototyping from a breadboard and desktop power supply. Additionally I will be using my Xmos StartKit development board, so no self designed PCB's yet.
Immediate To Dos:
Pictures:
IMGUR ALBUM
Links:
SOIC-8 to DIP-8 Breakout Board
Hall Effect Sensor
N-Channel Power Mosfet
Fairchild FAN7842, High/Low side, gate driver
3.5mm 3wire x 5 sets bullet wire connectors
28-30s 800kV 300W Turnigy motor
xMOS, startKIT multicore development board
