Ultra Simple 2x4 Server Rack
Back to overview
It doesn't get any easier or cheaper than this. Build a 4ft tall server rack from 2x4 BigBox hardware lumber.
eric wrote 03/30/2015 at 15:38 • point
You can screw 1x2's or bridging for rails, then your servers slide in and out and are supported in the back. Or screw the HP rails to the 2x4.
If you screw into the rack too much, and have to turn it around because you upgrade your servers too often, I think you should spring for a real rack.
