If you have programmed an Arduino and set up a LAMP server before, go straight to Github for the files and start tweaking.
If you need a little help putting this together for yourself, I'll be adding build instructions for each component as I have time.
I bought a lot of 10 nRF24L01+ modules for about $15, and found Arduino Pro Mini boards at $3.50 a piece in bulk so you can easily build out a dozen beacons for under $100. That'll make a good game around here at the Beach.
With a little modification to the App, you can tailor this to any event.
Hi, cool project you have got here.
I actually found this project from a link on aliexpress comments section while looking for NRF24L01 modules for exactly the purpose of making a beacon game.
You beat me to it.
I am planning on using ATTiny85 + NRF24L01 and power them with coin battery cells.
Great project and a fun idea. Keep it up.
