I was disappointed by the USB connector etched directly on the PCB. It turned out, that PCB must have been approx. 2.5mm thick to hold the device in it's place in the USB socket (I glued 3 layers of thin plastic which can be seen on the photos). So I decided to include "true" USB A connector after finding that they aren't so expensive.
lukasz.iwaszkiewicz
