New layout
A project log for CPU Gauge
An analog gauge with USB, serial and analog interface.
lukasziwaszkiewiczlukasz.iwaszkiewicz 10/27/2014 at 08:490 Comments
I was disappointed by the USB connector etched directly on the PCB. It turned out, that PCB must have been approx. 2.5mm thick to hold the device in it's place in the USB socket (I glued 3 layers of thin plastic which can be seen on the photos). So I decided to include "true" USB A connector after finding that they aren't so expensive.
