free spin tested to satisfaction
A project log for A plastic 400W alternator for smalll wind-turbine
A cost-effective micro-scale alternator build out of machining A3 sheets of plastic that aims to power basic human needs.
kostas-lagogiannisKostas Lagogiannis 10/29/2014 at 09:320 Comments
Trimmed edges holding axle ball bearings, this did the trick and allow rotor to freespin. So we have modified the design accordingly.
Further, the magnets where added and checked that loading does not impair spinning
Pic: most magnets added top stator liftedin this picture)
Further we added the small rotor extension wings that can be used to attach blades. Here the design needs to be modified so as to fasten these extensions more securely. Otherwise the 3 rotor laminates can be split appart by forces parallel to the axis of rotation .
(Pic of assembled rotor with magnets on both sides, ball bearings and extension wings)
