RC series Airfoils
A project log for Inexpensive Composite Propellers/Rotors
How to make inexpensive propellers using mostly hardware store materials and a CNC router
peter-mccloudPeter McCloud 03/02/2017 at 05:095 Comments
The previous rotor designs used generic NACA 2412 airfoils. These airfoils were developed over 80 years ago, but they are well documented and good general purpose airfoils. However to get the most thrust, airfoils specifically designed for rotors are required. Searching around led to the RC series of airfoils
RC series airfoils
The RC series of airfoils are specifically designed for rotorcraft applications. The naming scheme is RC(X)-YY where X is the number in the series and YY is the airfoil thickness in percent chord. Two of the airfoils, designed for the inboard section of rotor blades are the RC(4)-10, RC(5)-10. Data for these airfoils is found in:
NACA TP 3009 Aerodynamic Characteristics of Two Rotorcraft Airfoils Designed for Application to the Inboard Region
The other airfoil is the RC(6)-08 airfoil, designed for rotor tips. Data for this airfoil is documented in:
NASA TM 4264 Aerodynamic Characteristics of a Rotorcraft Airfoil Designed for the Tip Region of a Main Rotor Blade
Applying the new airfoils
Previously the rotor.py code was only written to use a single airfoil for the entire rotor. Recent updates allowed using two different airfoils, one a the tip and the second at the root. Changing the tip airfoil from the NACA 2412 to the RC(6)-08 means a 25% reduction in the chord. Since the bending moments are low at the tip, the thinner section doesn't affect the structural strength significantly.
Changing the root airfoil from the NACA 2412 to the RC(5)-10 airfoil means a 17% thinner airfoil. It may not seem like much, but the bending strength scales by the thickness cubed. Keeping the chord constant and changing from a 12% to 10% thick airfoil means a 42% reduction in bending strength.
To keep a similar strength with the thinner airfoil, the root chord will be increased from 4.5 to 5.4 inches to keep the overall thickness the same at the root. This leads to a negligible decrease in aerodynamic efficiency, but a big difference in the structural design.
So how big is the difference?
Rotor hover performance is measured by Figure of Merit (FM) vs. Efficiency. Hovering isn't doing any useful work so efficiency doesn't really apply. The FM is the ratio of the required power vs. the ideal required power. The previous rotors had a FM of about 60%. Analysis suggests the new rotors using the RC airfoils will have a FM of 80%.
Peter McCloud wrote 01/27/2018 at 07:18 point
Saabman wrote 01/27/2018 at 01:14 point
in a hovering situation wouldn't the work be against gravity
Chase Rayfield wrote 01/26/2018 at 16:05 point
"Hovering isn't doing any actual work"
That is wrong. The work done is the volume and speed of the air moved in the desired direction. Just because the craft doesn't move relative to the ground doesn't mean work isn't being done... the air is moving. Hovering requires work.... unless you are levitating which is different.
Peter McCloud wrote 01/26/2018 at 16:37 point
Work is force times distance. Yes, as you stated there is work applied to the flow, but since the vehicle remains motionless, no work is done on it. Since the input work is finite and the output is zero, the efficiency is zero.
I'll reword this to make it clearer I'm talking about the vehicle and not the flow.
Chase Rayfield wrote 01/27/2018 at 00:48 point
It is also nonsense... Ie if you don't have x armount of thrust you won't hover! without that work being done on the air there is no thrust... a more efficient rotor/propeller will require a smaller engine to produce the same thrust.
