3rd Gen Rotor Design
A project log for Inexpensive Composite Propellers/Rotors
How to make inexpensive propellers using mostly hardware store materials and a CNC router
peter-mccloudPeter McCloud 03/24/2017 at 03:250 Comments
The design for the 3rd gen rotor has been finalized and is shown below. The upper portion of the picture shows the rotor with the machining supports present. This is what the rotor looks like coming out of the CNC Router. The lower portion of the images shows the finished rotor with the supports removed. The airfoils for the tip and the root are highlighted.
