I/O mapping
10/28/2014 at 02:24 • 0 comments![]()
D3, D4, D5, D13 are used by the LCD.
D6..D9 are keyboard rows.
A0..A3 are keyboard columns. I intentionally map these backward so the physical wiring would be pretty. :-)WARNING: Note that the LCD is 3.3V!!!
Figuring out the keypad
10/28/2014 at 02:21 • 0 comments![]()
Using a multimeter, I deduced the rows and columns matrix of the keypad.
Incidentally, there is as much as 2K resistance on they keypress, so I could not use the beeper on the multimeter.
