Temperature Measurements
A project log for ESP8266 Native
Exploring running native applications on the ESP8266 modules
matt-callowMatt Callow 12/11/2014 at 11:190 Comments
I've updated the lua code to read the temperature from a 1-wire temp sensor using the code provided with the nodemcu firmware
Results are on the same thingspeak channel https://thingspeak.com/channels/17374
I'm quite impressed with the nodemcu firmware. It makes it very easy to write simple scripts like this. Still don't like the upload method though!
