Using the line inputs of XR385
A project log for Andreas' XG Synth module
Combining an XR385 karaoke card with and interface board and put it in low cost box
serdefserdef 10/28/2014 at 08:440 Comments
The XR-385 card has line inputs, similar to the Yamaha SW60XG. You can control these through sysex commands, see the commands here. It allows various effects and mixing with the synthesis output.
There's also a mod for these cards, here
Still to be tested
