The Rev 1.1 boards arrived a few weeks ago, but I have been too busy with other projects to update this log. Well, here we are now.
The new boards are pretty much perfect: the only error remaining is that the crystal's silkscreen is rotated 90 degrees from what it should be (you can see this in the image; the crystal is positioned with the long side vertical, whereas on the silk screen the long side is horizontal).
At this point I can solder one of these guys up in just about 30 minutes... not bad at all for a toothpick + heat gun job. :-)
The soldered board is shown below. Enjoy!
