NB_LED_Daughterboard.zip
6mm x 6mm castellated daughterboard for mounting a standard common-anode 0606 RGB LED in place of the fancy reverse-mount SunLED version we prefer.
Zip Archive - 217.87 kB - 05/04/2018 at 17:31
Download
foot7.stl
NeuroBeast v2 springy feet, ready to accept shoes. Use PLA, 0.2mm layer height, 20% infill, no supports or raft. Released under the terms of the GPL v3, as detailed in the LICENSE file.
Standard Tesselated Geometry - 246.37 kB - 05/27/2016 at 16:37
Download
body.stl
NeuroBeast v2 8-legged chassis *.stl file for printing. Use PLA, 0.2mm layer height, 20% infill, no supports or raft. Cams will likely need a bit of trimming to work reliably. Released under the terms of the GPL v3, as detailed in the LICENSE file.
Standard Tesselated Geometry - 712.97 kB - 05/27/2016 at 16:37
Download
LICENSE.txt
All NeuroBytes firmware and hardware are released under GPL v3.0. Read it!
plain - 34.32 kB - 05/15/2016 at 20:00
Download
Izhikevich model.ods
Spreadsheet used to model Izhikevich's neuron dynamics, both in floating point and integer format.
spreadsheet - 159.10 kB - 01/28/2016 at 20:26
Download
