Design change
11/20/2014 at 00:23 • 0 commentsAs anyone who has experience with 3d printing would know my previous design would not have worked as well as I thought. Therefore I decided on making a printer that uses thin plastic filament that is melted and slowly deposited in layers to make the final shape. I am lucky because minus the big tank my frame will be able to be used in the new printer.
Test 1
11/16/2014 at 01:57 • 0 commentsToday I conducted an experiment and found that my laser can not solidify the resin fast enough to build a consistent shape. This narrows down my options to the last of my three basic designs. I decided to order an old projector to use for the triggering source and a small electric pump to gradually fill the tank with solution.
