Test Run with 5V Regulation
A project log for 12V Battery Tester
A tester that can be used by high school students to test the batteries for capacity.
willbadenwillbaden 01/17/2015 at 22:200 Comments
The battery tester has been ran with the 5V regulator feeding the relay board. The UNO's voltage now locks in and does not fluctuate with the changing states of the relays. Here is an excerpt from the run:
Program Run 0 1240 -2 11001 4962
Program Run 5 1069 335 11101 4940
Program Run 10 1058 392 11101 4940
Program Run 15 1058 389 11101 4940
Program Run 20 1058 387 11101 4940
Program Run 25 1056 386 11101 4940
Program Run 30 1053 384 1111101 4940
Program End 35 1048 397 0 4940
This test and the prior versions test can be found on github.
