Going with the basics
A project log for ESP8266 Development PCB's
Development board for ESP8266 the make up of which can be decided by the community
michael-otooleMichael O'Toole 12/12/2014 at 02:290 Comments
As I have not had any requests for any additional functionality/connectivity, I will go with the original simple design. The PCB will be a through-hole version as I don't yet have all the equipment for SMD assembly.
The first test will use 902 firmware (ESP8266) and utilise the zeflo's "Weather Display" code... with some minor tweaks...
I will add all the necessary links and code...
Playing around with using ZIF for the ATMega?
12th Dec 2014
Decided to rearrange the components to make room for an inexpensive ZIF socket to allow quick changing of the 386P... Obviously you could just use a standard socket if you don't have a ZIF...
Might be a few more tweaks but will finalise the board this week end...
