A little Program Board
A project log for ESP8266 Development PCB's
Development board for ESP8266 the make up of which can be decided by the community
michael-otooleMichael O'Toole 03/18/2015 at 16:210 Comments
Just adding a little program board for ESP 01
All through-hole and single sided so easy to make...
J1 is a simple jumper to allow programming... remove for testing...
Also added a reset button and option two pin connector for supply (in place of 5 volt jack)...
