Removed from housing
A project log for Scanner Portable Video Light
Repurposing a Canon LiDe 500f Film Scanner Film Adapter Unit (FAU) for use as an adjustible portable light for video.
rebelj12aRebelj12a 11/17/2014 at 22:410 Comments
Well removed it from the housing. Going to take some pictures. I applied 5v from 4 AA batteries to the voltage pin. However nothing happened currently reading up on how others have connected an RGB scanner light up but the pictures are minimal to say the least not sure where to connect the ground. Pictures in a second.
Also nothing helpful or remarkable underneath the board.
