The project consists of a recorder/player that can record a sound message of approximately 12 seconds.
The device is divided into two blocks both based on a ChipCorder ISD1212 :
-a main device can record an audio message from a microphone and play from a speaker.
-a secondary device able to copy the message contained in the main device.
The device is thus not only a simple recorder/player, but allows you to broadcast the recorded message to a second minimal registration, to be used in others projects.
<a href="https://mipstudioblog.wordpress.com" target="_blank">https://mipstudioblog.wordpress.com</a>
