doing things w stuff
thought = thoughts(metal)
Untitled document =
/* sleep makes | minds weak */
todo:
#setup owncloud
#setup motion
Create home feature list
#shrink divs (doors,lights,power,etc…)
crearte moteino to rpi comunication
Usercake
Dual login Usercake and owncloud
Collapse Car home etc
Make divs fit on watch
make change password form in settings
#solder resistors between pin and FOB
add button press action
add button gifs
measure current input
connect local servers to web - ngInx load balancing
get OBD-pi python working
setup stats database to sync with owncloud (air, fuel, updates, temps, pressures, miles, etc...)
communicate server and moteino body sensors/actors (*motor sensors come from OBD-Pi)
vehical lane departure #1 cause of accidents
combine home and car servers
case 1:
user enters wifi zone around car -- car disarms
user can start car and access interior features
user leaves wifi zone around car -- car arms
case 2:
user taps NFC tag with NFC device (iphone, android, wearables)
tag command is executed (arm, disarm, start motor, etc...)
case 3:
user access car from any device with web browser
user can execute commands (arm, disarm, start motor, etc...)
user can view car history, change passwords, set access times, etc…
features:
#vehical lane departure #1 cause of accidents
sensor feedback
arm/disarm
horn
trunk
motor start
OBD-II
gps
camera
audio glass break
tow/hood tilt detect
battery disconnect alarm
rf transmitter
internet routing
home/business interface
#### ------ !!! gedanken !!! ------ #####
####-----HHHC(solid butane)CHHH------##
####-----if dipole < some_small_numbr------####
####-------- pressure * volume ~ constant * temperature-------####
####-------------- echo answer(constant == previous_constant) ---------------####
####------------------------if constant != 0 echo null!!!
///////////////////////////motion////////////////////////////////
apt-get -y update;apt-get install apache2 php5 mysql-server php5-mysql php5-json php5-gd php5-sqlite curl libcurl3 libcurl4-openssl-dev php5-curl php5-gd php5-cgi php-pear php5-dev build-essential libpcre3-dev php5 libapache2-mod-php5 php-apc motion libjpeg62 upstart libmysqlclient-dev;
pecl install apc;service apache2 restart;
#move owncloud
a2enmod rewrite;a2enmod headers;
sudo openssl genrsa -des3 -out server.key 1024; sudo openssl rsa -in server.key -out server.key.insecure;sudo openssl req -new -key server.key -out server.csr;sudo openssl x509 -req -days 365 -in server.csr -signkey server.key -out server.crt;sudo cp server.crt /etc/ssl/certs;sudo cp server.key /etc/ssl/private;sudo a2enmod ssl;sudo a2ensite default-ssl;service apache2 restart;
chown -R www-data:www-data /var/www/owncloud/;
#move: log into owncloud and make motion folder
#move: www
mysql -u root -p;
create database __fi;use __fi;
CREATE TABLE security (camera int, filename char(80) not null, frame int, file_type int, time text);
create table tokens(token text);insert into tokens values('--!!MATCHED!!--');
#mv .htaccess /var/www/owncloud/.htaccess;
#mv config.php /var/www/owncloud/config/config.php;chmod 777 /var/www/owncloud/config/config.php;
mv nph-mjprox /usr/lib/cgi-bin;chmod 777 /usr/lib/cgi-bin/nph-mjprox;
mv php.ini /etc/php5/apache2/php.ini;
mv 000-default /etc/apache2/sites-enabled/000-default;
mv motion /etc/motion/motion;chmod 777 /etc/motion/motion;
mv motion.conf /etc/motion/motion.conf;
mv motion.default /etc/default/motion;
mv apc.ini /etc/php5/cgi/conf.d/apc.ini
mv motioncontrol /etc/init.d/motioncontrol;chmod 777 /etc/init.d/motioncontrol;
update-rc.d motioncontrol defaults
#make owncloud motion folder
######nano /etc/default/motion;
#start_motion_daemon=yes
#nano /etc/php5/apache2/php.ini;...
View project log
ANANTHAKRISHNAN U S
Thaddaeus
lion mclionhead
Enki
Yes, delete it Cancel
You are about to report the project "echo answer(question)", please tell us the reason.
