1st Concept CAD Renderings
A project log for 3D Printable Raman Probe
This a 100% 3D printed Transmission Raman Probe (low resolution) W/built-in cuvette holder/Raman filter
david-h-haffner-srDavid H Haffner Sr 01/14/2018 at 15:070 Comments
This is the CAD program I use to build all my 3D parts FreeCad V16, this is the rough draft version, I think I'll have to construct a guide rail system for the rear fiber optic coupler because alignment of the laser line must be 100% perfect as it relates to the fiber optic end point.
Even though I have built in the diaphragm laser line guide, I still need a way to make final adjustments at this end.
I will have the blueprint draft drawings up soon when I have the final version finished.
