Finished painting the set
A project log for Spacehuhn badge
just a flashing rgb led badge
davedarkodavedarko 01/26/2018 at 13:586 Comments
I've decided on using the edding 4200 series on this run. I had to go over twice to get a good covering. Next time I'll try nailpolish though, since the color is still removable with Isopropanol, but tougher than with the 300 series.
Jarrett wrote 01/26/2018 at 19:07 point
You could also try a few passes of UV curing soldermask. Laser cut stencils might work fine for selectively blocking the UV.
davedarko wrote 01/26/2018 at 21:47 point
interesting idea :) I want to get something that's more robust against isopropyl.
deʃhipu wrote 01/26/2018 at 15:32 point
Are you using PCB stencils for this?
davedarko wrote 01/26/2018 at 17:47 point
nopes, just selling them as kits or handsolder them. it's just two LEDs, a switch, battery holder and the clip...
deʃhipu wrote 01/26/2018 at 20:32 point
I mean stencils for painting.
davedarko wrote 01/26/2018 at 21:46 point
ahhh, that would have been a good idea actually. I tried not to leave the white pads with the pen, but on the black it wasn't that bad. I've hit gold once or twice but was able to remove it.
