EasyIoT low power sensor board
A project log for EasyIoT framework
EasyIoT framework is cheap, reliable, secure IoT framework build from Raspberry Pi, Arduino and various sensors and transcivers.
easyiotEasyIoT 03/17/2015 at 12:460 Comments
Now we working on EasyIoT low power sensor board. It's size is 18x32mm and it's suitable for remote sensor nodes like door/window sensor, button, water leak sensor, soil moisture sensor, temperature and humidity sensor... Sensor node can easily operate between 5 and 10 years on 2 AA batteries.
Water leak sensor build by EasyIoT low power sensor board.
Current consumption 5.8µA.
