The Mark 2
A project log for 3D scanner
Takes 3D surface scans at close range. It is simple to construct as it uses off the shelf hardware and software.
jolarJolar 09/28/2021 at 09:480 Comments
Update:
I've made a "Mark 2" of this scanner which is way more accuracy, and it has a 2 axis turntable so you can scan objects from all sides easily.   I'm really proud of it now, its on a new project page...
https://hackaday.io/project/181346-3d-scanner-mk2
And I've launched it on Kickstarter, it has 2 days left to run (correct at 28th Sept 2021):
https://www.kickstarter.com/projects/jontupel/tupel3d-desktop-3d-scanner
Thank you all for showing such an interest.
