Revising the amplifier
A project log for Hakko 907 based Soldering Station
A soldering station based on the easy to source Hakko 907 soldering iron, which is a 24V 50W soldering iron with integrated thermistor.
kuroKuro 04/02/2015 at 10:060 Comments
I've noticed that the temperature sensor amplification could be improved.
Just follow these instructions:
  1. R3 of 10kohm
  2. R4 of 47kohm
  3. R5 of 1kohm
If you want an explanation, keep reading.
The equation for the op. amp. output voltage is given by:
\color{White} \large Vo = GAIN * 5V * \frac{Rsens}{R3 + Rsens}The ideal value for Vo is just below 5V when Rsens is at it's greatest value. Assuming Rsens of 200ohm when hot, calculating for 48x gain and R3 of 10kohm:
That means the max value at the output of the operational amplifier is 4.71V. We could increase this value and that would increase the precision in the temperature readings.
