Progress
A project log for Distance Analyzer 3000
Measuring device housed in an Altoids tin. Uses a rotary encoder with a wheel to estimate distance and display measurements on an LCD.
john-hamannJohn Hamann 01/04/2015 at 06:582 Comments
Well I've got about an hour an half left and so far I've managed to get the screen + trinket + battery working untethered. Now I only have to work the kinks out of my code. Because of the time crunch and lack of materials right now I have no power switch and there might be a tactile button floating around outside that changes units hopefully.
John Hamann wrote 01/04/2015 at 07:57 point
Oh well.
Eric Herbers wrote 01/04/2015 at 07:28 point
I hate to be the messenger, but as a fellow Midwesterner I feel you deserve the courtesy: The contest ended last night.
The deadline was 12 AM, 1-3-15, which was last night; not tonight. 12 AM is the beginning of a day so when a clock ticks from 11:59 to 12:00, the next day has commenced.
This can be confirmed through this post where they indicate that the contest has ended on the last paragraph:
http://hackaday.com/2015/01/03/trinket-edc-contest-usb-calipers/
Simple mistake and maybe they'll look past it, but just so you're not surprised when the contest winners are announced...
