Pictures, Pong, and Particle Physics
A project log for PIXO Pixel
EPS32 Based RGB Display that uses the APA102-2020 LED
sean-hodginsSean Hodgins 02/14/2018 at 13:530 Comments
Here is a run down on how to display a few things on the PIXO Pixel. I have made a python script to convert images into a C++ 8-bit array to put them in your code, show you how to make a quick game of pong, and finally, experiment with some particle physics!
